GZ 250 - Especificações
An entry-level cruiser that's inexpensive to own and operate, but with many classic styling features of larger cruisers.
Bright chrome finish on cylinder head covers, horn housing, tank emblems, and rear fender suspension struts.
Large Marauder-style fuel tank, rear fender and comfortable 2-piece seat with low 27.8 inch seat height.
Lightweight (302lbs.) - easier for the beginner or smaller rider to handle.
Four-stroke, single cylinder, SOHC, 2-valve engine with Twin Dome Combustion Chamber (TDCC). Provides a wide power band, good acceleration and high fuel efficiency, combined with the simplicity of a single cylinder engine.
Single Mikuni 32mm carburetor provides excellent throttle response.
Electric starter and digital transistorized ignition system powered by a maintenance-free battery.
5-speed transmission, with gear ratios ideally selected for strong engine performance under a variety of riding conditions.
Large 3.7 gallon fuel tank combined with fuel-efficient engine provides ample range for commuting or pleasure riding.
Long 57 inch wheelbase supported by oil-damped front forks and preload-adjustable twin-shock rear suspension for a comfortable ride.
Wide 110/90-16 front tire and 130/ 90-15 rear tire mounted on custom-style spoke wheels.
mais especificações:
eu achei num site gz 250 marauder
Suzuki GZ250 MSRP: $3,199.00
Engine: 249cc, four-stroke, SOHC, single cylinder, Twin Dome Combustion Chamber (TDCC)
Bore Stroke: 72.0 x 61.2mm
Compression Ratio: 9.0:1
Fuel System: Mikuni BSR32SS
Lubrication: Wet Sump
Ignition: Digital/Transistorized
Transmission: 5-speed
Final Drive: #520 chain
Overall Length: 2160mm (85.0 in.)
Overall Width: 815mm (32.1 in.)
Overall Height: 1090mm (42.9 in.)
Seat Height: 680mm (27.8 in.)
Ground Clearance: 125mm (4.9 in.)
Wheelbase: 1450mm (57.1 in.)
Dry Weight: 137kg (302 lbs.)
Suspension Front: Telescopic, oil damped
Suspension Rear: Twin shock, 5-way adjustable preload
Brakes Front: Single hydraulic disc
Brakes Rear: Mechanical drum
Tires Front: 110/90-16 59P
Tires Rear: 130/90-15 66P
Fuel Tank Capacity: 14.0 liter (3.7 gal.) 13.0 liter (3.4 gal.) CA. Model
Color: Black, Silver
O pneu da frente desta suzuki tem a mesma largura das nossas mirage...110
é uma boa moto, porém não deve ter preço competitivo no Brasil...
no site abaixo está escrito gz 250 marauder
http://www.totalmotorcycle.com/photos/2 ... -GZ250.htm
gostei da cor desta...
Paulão
Registrado em: 25 Mai 2008, 11:34
Um amigo meu, motociclista véio de guerra, me disse que em 2009 a Suzuki vai trazer a Boulevard 250 pro BR. Particularmente nem sabia que existia. Mais alguém ouviu algo sobre isso?
Edit: Achei esses anúncios:
http://coyoacan.olx.com.mx/traspaso-cre ... id-4194841
http://articulo.mercadolibre.com.mx/MLM ... d-2008-_JM
E esses comentários:
http://mx.answers.yahoo.com/question/in ... 209AAwjHiR
Paulo Tosetti
▲, C, ▼, C, ◄, ►, ◄, ►, A + Start
Lembrando que Boulevard é um nome utilizado nos EUA e na Europa eles chamam de Intruder... então pode ser que você tá falando da Intruder 250?
Paulão
Eh isso que o cara diz no comentario, que eh tambem chamada de marauder ou intruder, mas as fotos sao diferentes da Intruder 250. Mas se for a da foto eu nao achei "digna" do nome Boulevard. :?
Paulo Tosetti
Sou meio leigo nesse negócio de nomes da Suzuki pelo mundo, mas Boulevard é o nome nos EUA... :roll:
gildalfer
Esta moto é a GZ250, a nossa Intruder 250,
fabricada nos Estados Unidos (que por sinal tem 60 modelos de motos Suzuki à disposição do consumidor-igual a nós, hehehehe). Não sei se ela é fabricada no México, também.
Tem Intruder 250 na Austrália e N.Zelandia, só que no exterior ela é bicilíndrica.
Na Espanha tem a Marauder 125 (monocilíndrica) e Intruder 125 (bicilíndrica).
Tio Giba
intruderson
Registrado em: 20 Out 2008, 23:08
Ouvi varios comentarios, inclusive de concessionarias que ate o final de 2009 a Suzuki lançará a sua 250 e que o modelo seria esse ai abaixo:
  • Specs
    Engine: 249 cc (15.2 c*. in), 4-stroke, air-cooled, OHC
    Bore Stroke: 72.0 mm (2.835 in) x 61.2 mm (2.409 in)
    Compression Ratio: 9.0 : 1
    Fuel System: MIKUNI BSR32
    Lubrication: Wet sump
    Ignition: Electronic ignition (Transistorized)
    Transmission: 5-speed constant mesh
    Final Drive: DID 520V, 110 links
    Overall Length: 2160 mm (85.0 in)
    Overall Width: 815 mm (32.1 in)
    Overall Height: 1090 mm (42.9 in)
    Seat Height: 680 mm (27.8 in)
    Ground Clearance: 125 mm ( 4.9 in)
    Wheelbase: 1450 mm (57.1 in)
    Curb Weight: 150 kg (331 lbs)
    Suspension Front: Telescopic, coil spring, oil damped
    Suspension Rear: Swingarm type, coil spring, oil damped
    Brakes Front: Disc brake
    Brakes Rear: Drum brake
    Tires Front: 110/90-16M/C 59P, tube type or 110/90-16M/C 59S, tube type
    Tires Rear: 130/90-15M/C 66P, tube type or 130/90-15M/C 66S, tube type
    Fuel Tank Capacity: 13.0 L (3.4/2.9 US/Imp gal)
    Color: Black
Lá fora o nome dela é GZ250 aqui no Brasil ainda não tem nome definido.
Mito ou Verdade?
Grande Descida + Ação Social
Intruderson, você não tem o nome do modelo ou especificações? Afinal de contas o mercado de "Custom 250" nova no Brasil é pequeno e acho que seria muito bem vinda. Seria uma nova "Intruder 250"?
