Model LX250-3
Engine Type Two cylinder,4 stroke,air-cooled
Bore×Stroke (mm) 53.0×53.0
Piston Displacement (cc) 233.7
Compression Ratio 9.2:1
Max. Power (kw/rpm) 12.0/8500
Max. Torque (N.m/rpm) 14.5/5000~6000
Transmission System Chain Drive
Ignition Type CDI
Starter System Electric
Transmission 5 Speed
L×W×H (mm) 2280×860×1250
Wheel Base (mm) 1550
Ground Clearance (mm) 120
Dry Weight (kg) 185
Brake (Front/Rear) Disk/Drum
Tyre, Front 110/90-16
Tyre, Rear 130/90-15
Fuel Tank Capacity (L) 18
Engine Oil Capacity (L) 1.3
Max. Load Capacity (kg) 150
Max. Speed(km) 100
Battery(V/Ah) 12V/9Ah
loading(20'/40') 18/36
