Engine
Type 79-cubic-inch (1294cc) liquid-cooled, DOHC, 70-degree V-4
Bore x Stroke 79 x 66mm
Compression Ratio 10:1
Carburetion (4) 32mm Mikuni CV
Ignition Digital TCI
Transmission Wide-ratio 5-speed w/4th and 5th gear overdrive and hydraulic clutch
Final Drive Shaft
Chassis
Suspension/Front Telescopic fork w/air assist; 5.5" travel
Suspension/Rear Single shock, link-type w/air assist; 4.1" travel
Brakes/Front Dual 298mm Discs
Brakes/Rear 320mm Disc
Tires/Front 150/80-16
Tires/Rear 150/90-15
Dimensions
Length 98.6"
Width 39.8"
Height 60.0"
Seat Height 29.1"
Wheelbase 67.5"
Ground Clearance 5.9"
Dry Weight 787 lb.
Fuel Capacity 5.3 gal.
Other
Warranty 5 Year (Limited Factory Warranty)
