Engine
Type
Liquid Cooled V-8
Horsepower
502 @ 5200 rpm
Torque
567 Ft.Lbs @ 4200 rpm
Block
Cast Iron - 4 bolt main
Cylinders
Aluminum (110cc)
Valvetrain
2.25"Int. / 1.88"Exh
Size
502 c.i. (8200cc)
Compression
9.6:1
Carburetor
Holly 850 cfm
Exhaust
2.5" with dual mufflers
Transmission
2-speed semi-auto w/rev.
Final Drive
Belt, Gates- Polychain
Dimensions
Overall Length
108"
Wheel Base
82.0"
Seat Height
28.5"
Rake
33.0 degrees
Grd. Dlearance
4.5"
Frame Width
31.0"
GVWR
1827 lbs.
Dry Weight
1300 lbs.
Tires/Wheels
Front
130/90-16, 3.50"x16.0"
Rear
230/60, 7.0"x15.0"
Suspension (Adj. Preload)
Front
63mm inverted forks, 3.5" travel
Rear
Dual 13.5" coilover shocks
Brakes
Front
Dual four-piston calipers, 12.6" floating disc
Rear
Single four-piston caliper
Fuel
Tank
8.5 gal.
Reserve
n/a
High/Low MPG
18/13
http://www.bosshoss.net
