Category: Cruiser
Engine
Model: 253FMM
Type: Double-cylinder Parallel, air-cooled, 4-stroke
Bore×Stroke: 53 x 53 mm
Displacement: 233 cc
Maximum Power: 13kw @ 8500 rpm
Maximum Torque: 15N.m @ 7000 rpm
Clutch: Wet multi-plate
Lubrication: Pressure/splash
Start: Kick start/electric start
Ignition: C.D.I
Transmission: 5 gear
Maximum Speed: 115 kph
Fuel Consumption: ≤ 2.4L/100km
Chassis
Front brake: Disk
Rear brake: Drum
Front Tire: 110/90-16
Rear Tire: 130/90-15
Dimensions
L×W×H: 2330 x 840 x 1090 mm
Wheel base: 1500 mm
Minimum Ground Clearance: 145 mm
Dry Weight: 157 kg
Height Of Seat: 740 mm
Fuel Tank Capacity: 14 L
