BHC-9 502
Engine
Type
Liquid Cooled V-8
Horsepower
502 @ 5200 rpm
Torque
567 Ft.Lbs. @ 4200 rpm
Block
Cast Iron - 4 bolt main
Cylinders
Aluminum (110cc)
Valvetrain
2.25"Int. / 1.88"Exh
Size
502 c.i. (8200cc)
Compression
9.6:1
Carburetor
Holley 850 cfm
Exhaust
2.5" with dual mufflers
Transmission
3-speed automatic w/rev.
Final Drive
Shaft, narrowed Ford 7.5" (open)
Dimensions
Overall Length
("32) 117" / (`57) 131" / (Truck) 138"
Wheel Base
83.5"
Seat Height
29.0"
Rake
35.0 degrees
Grd. Dlearance
6.5"
Frame Width
60.0"
GVWR
2293 lbs.
Dry Weight
1700 lbs.
Tires/Wheels
Front
130/90-16, 3.50"x16.0"
Rear
275/60R-15, 10.0"x15.0"
Suspension (Adj. Preload)
Front
63mm inverted forks, 3.5" travel
Rear
Dual 17" coilover shocks, single 17.5" rebound damper
Brakes
Front
Dual four-piston calipers, 12.6" floating disc
Rear
9.0" drum brakes
Fuel
Tank
8.5 gal.
Reserve
3.5 gal.
High/Low MPG
18/13
