Triumph America - Especificações
Engine
Type Air-cooled, DOHC, parallel-twin, 270 degree firing interval
Capacity 865cc
Bore/Stroke 90 x 68mm
Compression Ratio 9.2:1
Fuel System Twin carburettors with throttle position sensor and electric carburettor heaters
Ignition Digital - inductive type
Transmission Primary Drive Gear
Final Drive X ring chain
Clutch Wet, multi-plate
Gearbox 5-speed
Cycle Parts Frame
Tubular steel cradle
Swingarm Twin-sided, tubular steel
Front Wheel Alloy 12-spoke, 18 x 2.5in
Rear Wheel Alloy 12-spoke, 15 x 3.5in
Front Tyre 110/90 18
Rear Tyre 170/80 15
Front Suspension 41mm forks
Rear Suspension Chromed spring twin shocks with adjustable preload
Front Brakes Single 310mm disc, 2 piston calipers
Rear Brakes Single 285mm disc, 2 piston caliper
Dimensions
Length 2420mm (95.2in)
Width (Handlebars) 960mm (37.8in)
Height 1170mm (46.1in)
Seat Height 720mm (28.3in)
Wheelbase 1655mm (65.2in)
Rake/Trail 33.3 degree/153mm
Weight (Dry) 497 lbs
Fuel Tank Capacity 4.4 gal US
Performance (Measured at crankshaft to DIN 70020) Maximum Power 55PS (54bhp) at 6,750 rpm
Maximum Torque 69Nm (51ft.lbf) at 4,800 rpm
Colours
Phantom Black/Sunset Red, Phantom Black/Tornado Red, Phantom Black, Pacific Blue/New England White
Esta América, é uma versão da Triumph Bonneville destinada ao público norte americano...
ver mais em:
http://www2.uol.com.br/bestcars/motos/triumph-3.htm
abração :wink:
