Model: Suzuki VL 125 LC Intruder
Year: 2001
Category: Custom / cruiser
Rating: 76.1 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 124.00 ccm (7.57 cubic inches)
Engine type: V2
Stroke: 4
Power: 13.50 HP (9.9 kW)) @ 10500 RPM
Torque: 10.00 Nm (1.0 kgf-m or 7.4 ft.lbs) @ 8000 RPM
Bore x stroke: 44.0 x 40.9 mm (1.7 x 1.6 inches)
Fuel system: Carburettor
Valves per cylinder: 3
Gearbox: 5-speed
Transmission type
final drive: Chain
More details Consult a Suzuki repair manual.
Physical measures
Dry weight: 140.0 kg (308.6 pounds)
Seat height: 685 mm (27.0 inches) If adjustable, lowest setting.
Wheelbase: 1,520 mm (59.8 inches)
Chassis and dimensions
Front suspension travel: 120 mm (4.7 inches)
Rear suspension travel: 90 mm (3.5 inches)
Front tyre dimensions: 90/90-18
Rear tyre dimensions: 130/90-15
Front brakes: Dual disc
Front brakes diameter: 275 mm (10.8 inches)
Rear brakes: Expanding brake
Rear brakes diameter: 130 mm (5.1 inches)
Speed and acceleration
Top speed: 100.0 km/h (62.1 mph)
Power/weight ratio: 0.0964 HP/kg
Other specifications
Fuel capacity: 12.00 litres (3.17 gallons)
Fonte: BikeZ
