Engine
Type: 4-Stroke, Vertical Parallel Twin, Air Cooled
Bore x Stroke: 53mm x 53mm
Compression Ratio: 9.4:1
Starter: Electric
Carburetion: ISO – Vacuum Diaphragm
Displacement: 233 cc
Max. Torque: 15 / 7000
Horse Power: 18 HP
Ignition: CDI
Transmission: 5-speed
Chassis
Suspension/Front: Telescopic
Suspension/Rear: Twin Shock
Brakes/Front: Disc
Brakes/Rear: Drum
Tires/Front: 110/90-16
Tires/Rear: 130/90-15
Dimensions:
Length: 84.6”
Width: 33.1"
Height: 42.3"
Seat Height: 25.5"
Ground Clearance: 5.3"
Wheelbase: 57.1"
Dry Weight: 337 lb
Fuel Capacity: 3.7 gallons
Other
Warranty: 2 Year Limited
MSRP: $2450.00 (Not including shipping, setup, and state fees)
