Specifications
MEASUREMENTS
Width 30.5"
Length 89"
Height 45.6"
Wheel Base 58"
Seat Height 27"
Ground Clearance 6.1"
Dry Weight 308LBS
Max Load 330LBS
RIMS, TIRES & SUSPENSION
Front Rim/Tire 110/90 - 16"
Front Brake DISC
Front Suspension TWIN
Rear Rim/Tire 130/90 - 15"
Rear Brake DRUM
Rear Suspension TWIN
ENGINE & TRANSMISSION
HP 16.6HP
Battery Amp 9 AMP
Cooling AIR
Cylinder 2
Cycle 4
Start Method CDI
Transmission MANUAL 5 SP
Oil Type 10W - 40
Oil Cap 1.6L
OTHER
Gas Tank Cap 3.7 GALLONS
Muffler DUAL
Warranty 3 YEARS LIMITED
