Johnny Pag - Raptor 300 - Especificações
The Raptor 300 was designed for our customers that like to ride long distances in comfort and style. The Raptor is driven by a 300cc engine which cruises between 70 and 75 mph while getting 60mpg (est.) Like our Spyder, the Raptor also comes stock with dual disc front brakes and stainless brake lines for great stopping power. All of our paint is brilliant pearl offered in 3 different color schemes with matching custom rims. We offer saddle bags for our customers that like to pack extra clothes and a windshield for the rider that wants to stay out of the wind.
ENGINE
Engine Type 300cc liquid-cooled parallel twin-cylinder 4 stroke
Bore and Stroke 57.0mm x 53.0mm
Compression
Ratio
10.2:1
Valve Train DOHC; two valves per cylinder
Induction Dual 26mm Keihin Vacuum carburetor
Ignition CDI
Fuel 93 Octane
Oil 10w 40
Engine
Lubrication
Forced Lubrication
HP 23.8/6500 RPM
Torque 18.5/6500 RPM
Idle Speed 1400-1600 RPM
Spark Plug A6RTC/A7RTC
DRIVE TRAIN
T ransmission 5-speed
G ear Ratio 1st 2.846 2nd 1.77 3rd 1.333 4th 1.083 5th 0.913
F inal Drive Chain KMC 530H
C lutch Multiplate oil bath
CHASSIS / SUSPENSION / BRAKES
Front
Suspension
37mm forks
R ear Suspension Dual rear shocks
F ront Brake Dual-disc with twin-piston calipers
R ear Brake Single disc with twin-piston caliper
F ront Tire 90/90/18
R ear Tire 130/90/15
Front Rim 18”x3” Alloy
R ear Rim 15”x3.75” Alloy
Tire pressure
Front
35 Psi
Tire pressure
Rear
35 Psi
DIMENSIONS
R ake 36 degrees
W heelbase 62” inches
S eat Height 26” inches
C urb Weight 360 lbs
Ground
Clearance
6”
Fuel Capacity 4.2 gallons
F uel Economy 65 MPG
OTHER
Emissions
Meets Current EPA standards. California version differs slightly
due to emissions equipment.
Available Colors Solid Black, Solid Red, Solid Silver
Model ID Raptor 300
FACTORY WARRANTY INFORMATION
6 Months Coverage of defects in materials and workmanship
Eles ainda tinham um modelo de 250cc que foi descontinuado:
Link
