DAYSTAR 124.1cc
Air-cooling 4 stroke 4-valve engine.
Brake: Front-Disc / Rear-Drum.
GENERAL
Length x Width x Height (in) 88.18 x 31.10 x 45.27
Wheel Base (in) 59,25
Ground clearance (in) 5,12
Seat height (in) 27,56
Dry weight (lbs) 352,42
FRAME
Fuel tank capacity (gal) 4,57
Brake (FR) / (RR) Disk / Drum
Tire (FR) / (RR) 90/90-18, 130/90-15
Suspension (FR) / (RR) Telescopic / Swing arm
ENGINE
System Air and Oil cooled 4 stroke - 4 valve
Displacement (cc) 124,1
Bore x Stroke (in) 2.22 x 1.95
Compression ratio 11.5:1
Carburator type PD Type
Starting system Kick and Electric start
Transmission 5 step return
Ignition system C.D.I.
Max. power (ps) 13,2
Horse power (hp) 13
