Loncin - LX125-7 - Especificações
Moto: Amazonas AME
Model LX125-7
Engine Type One cylinder,4 stroke,air-cooled
Bore×Stroke (mm) 56.5×49.5
Piston Displacement (cc) 124
Compression Ratio 9.1:1
Max. Power (kw/rpm) 7.5/8500
Max. Torque (N.m/rpm) 8.5/7500
Transmission System Chain Drive
Ignition Type C.D.I.
Starter System Electric/Kick
Transmission 5 Speed
L×W×H (mm) 1910×840×1100
Wheel Base (mm) 1300
Ground Clearance (mm) 180
Dry Weight (kg) 118
Brake (Front/Rear) Disk/Drum
Tyre, Front 2.75-18
Tyre, Rear 3.50-16
Fuel Tank Capacity (L) 9.5
Engine Oil Capacity (L) 1
Max. Load Capacity (kg) 150
Max. Speed(km) 85
Battery(V/Ah) 12V/7Ah
loading(20'/40') 39/84
intruder 125 :evil:
