Loncin - LX150-6E - Especificações
Moto: Amazonas AME
Model LX150-6E(CG150)
Engine Type One cylinder,4 stroke,air-cooled
Bore×Stroke (mm) 62.0×49.5
Piston Displacement (cc) 149
Compression Ratio 9.0:1
Max. Power (kw/rpm) 8.5/8500±500
Max. Torque (N.m/rpm) 10/6500
Transmission System Chain Drive
Ignition Type C.D.I.
Starter System Electric/Kick
Transmission 5 Speed
L×W×H (mm) 2270×840×1170
Wheel Base (mm) 1460
Ground Clearance (mm) 175
Dry Weight (kg) 163
Brake (Front/Rear) Disk/Drum
Tyre, Front 110/90-16
Tyre, Rear 130/90-15
Fuel Tank Capacity (L) 12
Engine Oil Capacity (L) 1.1
Max. Load Capacity (kg) 150
Max. Speed(km) 95
Battery(V/Ah) 12V/7Ah
loading(20'/40') 22/44
