BMW R 1200 RT-P - Especificações
wellrod
Ride with even more authority.
The R 1200 RT-P sets the benchmark for authority motorcycles not only in the United States but around the world. Boasting a generous 110 hp Boxer engine with a low center of gravity, a dynamic Telelever front suspension and full fairing weather protection, the R 1200 RT-P offers amazingly precise handling. BMW EVO brakes with partially Integral ABS II mean quick stops on gravel, concrete, and even wet road surfaces. The new R 1200 RT-P also features completely new LED emergency lighting, with programmable flashing and sirens. Twenty-three liter saddlebags provide ample storage space for officers, and with a sturdy stainless steel front protection bars, the R 1200 RT-P also offers maximum protection. Handlebar and cockpit areas offer mountings for many accessories, such as moving radar, video systems, map lights, notepad holders and electrical outlets. With an electrically- adjustable windshield for weather protection, a maintenance-free gel battery, a 39 months, 60,000 mile limited warranty, and the R 1200 RT-P is the premiere option for law enforcement agencies. Now those bad guys don't stand a chance.
Type: Air/oil-cooled 2-cylinder 4-valve head twin motor
Displacement: 1170cc
Bore X Stroke: 101 mm x 73 mm
Horsepower: 110 hp at 7,500 rpm
Torque: 85 lb/ft @ 6000 rpm
Valve Gear: HC, chain-driven
No of cylinders: 2
Compression Ratio: 12.0:1
Engine Management: Electronic intake pipe injection / digital engine management BMS-K with dual ignition & overrun fuel cut-off
Valves per Cylinder: Four
Valves: 2 x 36.0 mm intake / 2 x 31.0 mm exhaust
Fuel Tank: HDPE, internal pump and internal filter
Alternator W: 720 Watts @ 14 Volts
Battery V/AH: 12 Volts / 19 Amps/hour
Engine Summary:
The two cylinder flat twin Boxer engine is BMW's famous, time-tested, signature design. First designed in 1923, its two horizontally mounted cylinders are like a boxer's gloves punching each other as he enters the ring. The result is a supremely reliable, flexible engine with a low center of gravity and like all twins, excellent torque characteristics. The exposed cylinders offer excellent air cooling and if it's durability, performance, and bulletproof all-around handling you want, this is your powerplant.
Overall Length: 87.8 inches
Overall Width: Approximately 36 inches
Wheelbase: 58.4 inches
Seat height: 32.2 inches
Weight - Dry: varied based on setup
Max permissible weight: 1091 lbs
Fuel Capacity: 7.1 U.S. gallons ; including 1 gallon reserve
Wellington Rodrigues
DESVIRTUADOR
Shadow 750 - Aparecida
Nova Iguaçu- RJ
http://w.rodrigues.nafoto.net
Moto da BMW ganha novos componentes e preço de até R$ 77,9 mil
FABIANO SEVERO
da Folha de S.Paulo
As motos da BMW não são iguais às outras. De cara, parecem grandes e pesadas demais para andar na cidade e "beberronas" ao extremo na estrada.
Pura injustiça de quem nunca guiou uma BMW R1200GS. É verdade, são realmente grandes, mas fáceis de pilotar para quem tem mais de 1,80 m. Afinal, são feitas na Alemanha.
Quem for mais baixo terá o alento da regulagem do banco do piloto -varia de 850 mm a 870 mm do chão. Com espuma mais densa, ele pode ser retirado e ajustado para quem quer apoiar toda a planta do pé no chão. E com toda a razão -são 203 quilos e só duas rodas.
Mais baixo, o piloto também tem a vantagem de ficar atrás da bolha frontal, que pode ser regulada em altura para proteger do vento e, principalmente, do frio. De novo, ela é alemã.
E nem precisa nevar para agradecer aos deuses por aqueles centímetros a mais de plástico moldado. Nesse outono com cara de inverno, a subida do litoral sul de São Paulo para a capital já requer proteção.
Estouros
As mãos também estão a salvo. Há proteção para os punhos e até aquecimento de manopla, que pode ser regulada em duas temperaturas. A mais quente, sabe-se lá a quantos graus Celsius, parece que vai torrar a pobre palma da mão.
Lá, na Imigrantes, é que a R1200GS mostra por que custa até R$ 77,9 mil. Há dois discos na dianteira com ABS (antitravamento) e suspensão regulável para passeios com garupa e mais três maletas de bagagem.
O equilíbrio dinâmico é incrível, a ponto de ser possível soltar o guidom e esperar a moto quase parar, sem querer tombar. De novo, é o dedo da Alemanha, onde alguns fabricantes ainda acreditam na boa e velha teoria do senhor Ferdinand Porsche: motor é "boxer", com cilindros contrapostos.
Isso abaixa o centro de gravidade do carro e aumenta a estabilidade. Na R1200GS, é igual.
Parada, é de se estranhar a movimentação dos dois cilindros de 1.170 cm3 de cilindrada. Uma subida de giro até 8.000 rpm faz a moto balançar.
Em movimento, porém, gera 12 kgfm de torque, o que é mais importante que seus 105 cv.
É suficiente para arrancar e fazer ultrapassagens rápidas. A 120 km/h, a indicação da sexta marcha no painel digital é a segurança de baixo ruído do escapamento lateral, que volta e meia libera um estouro nas reduções fortes. Será que nem a gasolina "Podium" é igual à da Alemanha? Que a Petrobras não leia essa insolência.
A moto foi cedida para teste pela BMW
talvez essa moto seja a solução para aqueles que tem mais de 1,80m e acham que vão ficar muito desconfortáveis numa mirage... hehehhe :lol: :lol: :lol: O preço é quase igual... hehee :lol:
Fiz uma postagem sobre a
BMW 1200 RT no meu site, no link:
http://axiologico.blogspot.com/2008/06/ ... 00-rt.html
postei umas fotos e a ficha técnica da motinho...heheh
