Só para crianças? - Mini Chopper
Shanghai Mainbon Industry Co.,Ltd é o nome da fabricante chinesa de motos para crianças, ou deveria ser para crianças... rsrsrsrsrs
Já vi marmanjo andando com essas coisas nos encontros do Ibira Moto Point.
Você compraria para seu filho? :wink:
Bom, deixando de lado um pouco essa parte vou colocar os modelos disponíveis na China:
Model No: GS-049
Displacement: 49cc, 2 stroke
Starting system: pull and electric starting
Engine: two strokes, one cylinder, air-cooling
Hydraulic suspension (front)
Tire: Front: 90/90-12, Rear: 130*60-4
Brake: Front: hand brake, hydraulic brake
Rear: foot brake, drum brake
Maximum speed: 45km/h
Range: 40-50kms
Gross weight: 42kgs
Net weight: 36kgs
Model No: GS-071
Engine Type: 50cc,single cylinder,air-cooling,4 stroke
Max Load: 95kgs
Gas Tank Capacity: 5000ml
Ground Clearance: 105mm
Front Type: 3.50-18.2-12-6pr
Rear Type: 5.1-16.3-10-6pr
Front Brake: Disk (Hydraulic)
Rear Brake: Drum Brake (foot control)
Front Suspension: Hydraulic Spring Double Shock
How to Start the Engine: Electric Start
Exhaust System: Dual Pipe Muffler
N.W./G.W.: 70/72kgs
Product Size: 1760*620*860mm
Carton Size: 1560*450*660
by OCC?
Model No: GS-089
TOP FEATURES
THE INNOVATIVE DESIGN!
FRONT AND REAR HYDRAULIC DISC BRAKES!
METAL GAS TANK WITH KEY
110CC 4 STROKE 4 SPEED CLUTCHLESS ENGINE
REAR CENTRAL SHOCKS
BEATIFUL V-SHAPED HANDLE BAR
SEPERATE PEDAL FOR DOWNSHIFTING
CUSTOM SEAT DESIGN
LARGE CUSTOM HANDLE GRIPS
PREINSTALLED LARGE CONE AIR FILTER
HIGH STRENGTH GOLD CHAIN
Maximum Speed: 50mph
Range: 50 to 70 Miles per tank
FRONT WHEEL: 2.15"x14"
REAR WHEEL: 4.5"x12"
Brakes: FRONT AND REAR HYDRAULIC DISC BRAKE
Carrying Capacity: 300 lbs
Batteries: 12v, 7Ah
Transmission: 4/GEAR SEMI AUTOMATIC CLUTCHLESS (UNICYCLE)
Gas Tank: 4L
Starter: ELECTRIC START AND KICK START
Item No: GS-090
Engine: 49.5CC, 4 stroke
Speed: 45--70km/h
Load: 150kg
Oil tank volume: 5.5L
Starting system: electric starter/kick
Transmission: chain
Brake: Front disk, Rear drum
Fire mode: CDI
Ground clearance: 105mm
Wheel size: 90/90-12(F) 130/60-10(R)
Wheel base: 1410mm
Net weight: 67kgs
Gross weight: 77kgs
Products size: 1830x560x900mm
Carton size: 164x45x75cm
Container: 51pcs/20'Qty 108pcs/40'HQ
Color: red / black / blue / orange / silver / gold
Model No: GS-090A
LengthWidthaHeight:1980a730a990mm
Wheelbase:1480mm
Net weight:71kgs
Payload:150kg
Front wheel:2.75-14
Rear wheel:205/30-11
Ignition means: CDI
Speed, max: 45km/h
Braking distance:?7m(30km/h)
Climb ability: 15
Cylinder bore stroke:39mm40.2mm
Compression ratio:7.3:1
Output,max:2.6kw/8500rpm
Torque,max:3.0N.m/7500rpm
Idling speed:1400r/min+150r/min
Displacement of cylinder:49.5CC
Spark plug:A7TC XS
Spark plug gap:0.6mm-0.7mm
Fuel tank capacity:5.5L
Ground clearance:150mm
Carton size: 1390x450x660mm
Container: 164pcs/40HQ
ITEM NO:GS-091A
Engine: 49.5CC, V-Twin cylinder, 4 stroke
Speed: 45km/h
Load: 150kg
Fuel tank volume: 5.5L
Starting system: electric starter/kick starter
Transmission: chain
Brake: front disc, rear disc
Fire mode: CDI
Wheel size: 2.75-14(F), 205/30-11(R)
Material of hub: Al-alloy
Wheel base: 1680mm
Seat High: 470mm
Ground Clearance: 100mm
Net weight: 80kgs
Gross weight: 90kgs
Products size: 2150x800x880mm
Carton size: 1480x450x660mm
Container: 54pcs/20'GP, 120pcs/40'GP, 158pcs/40'HC
Model No: GS-092
Features:
1) Engine: 110cc, 4-stroke, (125cc, 150cc available)
2) Max. load: 90kg
3) Max. speed: 70kph
4) User age: >14
5) Brake F/R: hydraulic disc
6) Transmission: manual clutch, 4-speed
7) Max. power: 2.2kW/7,500rpm
8) Battery: 12V 4Ah
9) Drive model: chain
10) Fuel tank cap: 4L
11) Ignition mode: CDI
12) Start: electric / kick
13) Tire size: front: 70/80-13, rear: 160/40-10
Different colors are available.
Outer packing:
Carton dimensions: 149 x 41x 71cm
N.W.: 80kg
G.W.: 89kg
Na boa tem modelos de 100cc, isso para criança? rsrsrsrsrs
Muitas imitações de motos da OCC... bom fica aí o tópico para o debate... :roll: :arrow:
Se o meu filho de 3 anos olhar isso.... me dei mal... vai querer.. hehehhee....
bem legais as motinhos... se tivesse grana compraria pro meu filhote quando ficar maiorzinho...
Tank Minicustom 50 2007
Specifications
MEASUREMENTS
Width 18"
Length 64"
Height 42"
Wheel Base 47"
Seat Height 24"
Ground Clearance 3.3"
Dry Weight 198LBS
Max Load 286LBS
RIMS, TIRES & SUSPENSION
Front Rim/Tire 2.25 - 17"
Front Brake DISC
Front Suspension TWIN
Rear Rim/Tire 4.5 - 12"
Rear Brake DRUM
Rear Suspension TWIN
ENGINE & TRANSMISSION
HP 2HP
Battery Amp 5 AMP
Cooling AIR
Cylinder 1
Cycle 4
Start Method CDI, KICK
Transmission AUTO, SEMIAUTO, MANUAL
Oil Type 10W - 40
Oil Cap 0.9L
OTHER
Gas Tank Cap 1.6 GALLONS
Muffler SINGLE
Warranty 3 YEARS LIMITED
Tank Nascar Signature Series
Specifications
MEASUREMENTS
Width 18"
Length 64"
Height 42"
Wheel Base 47"
Seat Height 24"
Dry Weight 198LBS
Max Load 286LBS
Front Brake DISC
Rear Brake DRUM
HP 2HP
Battery Amp 5 AMP
Cooling AIR
Cylinder 1
Cycle 4
Oil Type 10W - 40
Oil Cap 0.9L
OTHER
Muffler SINGLE
rgallas
Vizinho meu deu pra filha uma motinho.
Ela caiu, bateu a cabeça numa pedra e quase ficou cega.
Criança tem que jogar bola, esconde-esconde, etc...
Roque Gallas Jr.
Vendendo máquinas
www.metalsystem.ind.br
wellrod
creio que desde que num lugar apropriado e com a segurança apropriada, nada demais... não esqueçamos que os atuais corredores de F1 e Motoracers começaram de criança... já tá no sangue...
me lembro que quando eu era pequeno, tinha uma caloicross... aí ia para o pátio de um supermercado lá perto de casa pra ver um outro menino que tinha um kart... era meu sonho poder andar em um... mas... a vida passou, eu ganhei meus 2 metros de altura e hoje o único kart que eu consigo entrar é meu pálio... rsrsr
Wellington Rodrigues
DESVIRTUADOR
Shadow 750 - Aparecida
Nova Iguaçu- RJ
http://w.rodrigues.nafoto.net
Realmente é perigoso... tem que usar capacete e roupas adequadas como qualquer outra moto... e ter muito cuidado...
pois 50cc é igual a uma JOG... e anda a uns 80km/h
wellrod
e se tá no sangue num tem jeito... vc pode adiar o quanto puder... mas um dia ele vai comprar a moto dele... com 3 ou com 30... (meu caso... ahuahauh)
DESVIRTUADOR
Nova Iguaçu- RJ
rgallas
Concordo com vocês;
É que criança não tem dissernimento sobre o que é perigoso ou não.
Esses "brinquedos" precisam ser supervisionados de perto pelos adultos. Criança não usa capacete porque é perigoso, usa porque os pais mandaram.
Vejo muito essa história de que velocidade tá no sangue. Mas na maioria das vezes tá no sangue do pai que quer ver o filho fazer o que não fez. Corri rally durante um tempo e presenciava isso no meio automobilistico.
Criança até determinada idade tem que escolher seus brinquedos. Tenho um afilhado que só ganha carrinho de brinquedo porque o pai correu rally, corre de kart e quer que filho seja assim tambem. O único que dá algum jogo diferente pra ele sou eu. Aliás ele tá de aniversário hoje. 6 anos.
Depois que ele mostrar o que quer de verdade vou ser o primeiro a botar pilha. Pior que ele leva geito pra coisa. Anda de carrinho de lomba (rolimã) como um doido.
Roque Gallas Jr.
Vendendo máquinas
wellrod
aí vc tá coberto de razão... mas são casos diferentes... realmente quando os pais escolhem as profissões dos filhos as coisas tendem a não dar certo... mas aí num é necessariamente no motociclismo... é em QUALQUER profissão... por meus pais eu ainda estaria na marinha até hoje... foi preciso muita coragem de enfrentá-los e dizer o que eu realmente queria pra minha vida... o que realmente me faria feliz...
DESVIRTUADOR
Nova Iguaçu- RJ
