Bennche - Megelli 250R - Especificações
- Administrador
Engine
Engine Type Four-Stroke, Single Cylinder
Displacement 249 cc
Bore & Stroke 77 x 53.6mm
Compression Ratio 11.5:1
Fuel System Carbureted
Ignition CDI
Transmission 6-speed
Drive Train Chain Drive
Cooling Liquid
Horse Power 27 HP
Fuel Tank Capacity 3 gallons
Battery 12 volts 9 amp
Dimension
Overall Length 78.3 in.
Overall Width 30.7 in.
Overall Height 41.7 in.
Seat Height 31.5 in.
Ground Clearance 6 in.
Front Tire 100/70-17
Rear Tire 130/70-17
Wheelbase 53.1 in.
Dry Weight 248 lbs
Suspension
Front Suspension Telescope Suspension
Rear Suspension Mono-shock Absorber
Brake
Front Brake Hydraulic Disc
Rear Brake Hydraulic Disc
Other
Color Black, Red, Yellow
Warranty 18 Months Limited Warranty
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/fHUnrPYuOEo?fs ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/fHUnrPYuOEo?fs=1&hl=pt_BR" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Referência: http://www.bennche.com/product/Megelli_250r-gallery.htm
