Make Model
Honda VF 750C Magna
Engine : Liquid cooled, four stroke, 90°V-four cylinder, DOHC, 4 valve per cylinder.
Capacity: 748
Bore x Stroke: 70 x 48.6 mm
Compression Ratio: 10.5:1
Induction : 4x 32mm Keihin carbs
Ignition / Starting: CDI / electric
Max Power : 79 hp 57.6 kW @ 9500 rpm
Max Torque : 66 Nm @ 7500 rpm
Transmission / Drive: 6 Speed / shaft
Front Suspension: 39mm Air assisted forks, 4-way anti-dive adjustable. 120mm wheel travel.
Rear Suspension: Dual shocks, spring preload adjustable, 99mm wheel travel.
Front Brakes: Single 315mm disc
Rear Brakes: Drum
Front Tyre: 120/90 -17
Rear Tyre: 150/80 -17
Seat Height 710 mm / 28.0 in
Dry-Weight: 228 kg
Fuel Capacity : 13 Litres
Consumption: average 37 mp/g
Standing ¼ Mile : 12.3 sec / 108.7 mp/h
Top Speed : 122 mp/h
Magna 750 - Especificações
- jfreitas89
- Registrado em: 08 Jul 2010, 19:47
