Drag Star 1100 - Especificações
2007 Yamaha DragStar 1100
Category: Cruiser
Also called:
Yamaha DragStar Eleven
Yamaha DS11
Specifications:
Engine
Model: P610E
Type: Air cooled 4 strokes SOHC 2 valves
Cylinder: V type 2
Displacement: 1,063cc
Bore x stroke: 95.0mm x 75.0mm
Compression ratio: 8.3 : 1
Maximum power: 45kW (60PS) @ 5,750rpm
Maximum torque: 82N m (8.3kgf m) @ 2,500rpm
Starting system: Cell system
Lubricating system: Forced force wet sump
Carburetor type: BSR37×2
Ignition system: T.C.I. Formula
Powertrain
Primary drive: Gear/1.659 (78/47)
Final drive: Shaft/2.874 (44/47×19/18×32/11)
Clutch type: Wet multiple plate coil springs
Transmission type: Return type 5 step
Change gear ratio:
1st: 2.352
2nd: 1.666
3rd: 1.285
4th: 1.032
5th: 0.852
Chassis
Frame type: Double cradle
Caster/trail: 33°00 ‘/136mm
Front brake: Hydraulic type double disk
Rear brake: hydraulic type single disk
Front tire: 110/90-18M/C 61S
Rear tire: 170/80-15M/C 77S
Dimesions/weight/capacity
LWH: 2,405mm x 895mm x 1,100mm
Wheelbase: 1,640mm
Seat height: 690mm
Dry weight: 262kg
Weight equipped: 278kg
Minimum turning radius: 3.2m
Motor oil capacity: 3.6L
Fuel tank capacity: 17L
Fuel economy: 32.0km/L @ 60kph
Electricals
Battery capacity/type: 12V-12Ah (10h)/GT14B-4 (MF)
Headlight: Halogen valve (60W/55W)
Available only in:
Japan
Não entendo nada de preço, então lá vai (não que eu irei comprar...rsrsrsr)...
Drag Star 1100 por R$25,000.00???? o preço é esse mesmo? ela vale isso??? Ta caro ou barato??? :lol: :lol:
http://www.motoecia.com.br/pesquisa/des ... delo=27106
E se alguem quiser me da uma de presente tudo bem!!!!!
ulissesmarques
De tabela essa Drag 1100 ano 2000, tá R$27.000,00
:shock:
Lissão
2.13.3
bongocero05
Registrado em: 20 Jan 2009, 18:11
Que isso!
torque máximo: 82N m (8.3kgf m) @ 2,500rpm
Isso é um chute no peito hehekkkkkkkkk
Sou louco pra ter uma dessa, devagar a gente chega lá.
Aviaum69
Registrado em: 06 Jan 2009, 15:42
Ai sim, parece CG
Ha Braço
