Triumph - Rocket III - Especificações
Engine Type Liquid-cooled, DOHC, in-line 3-cylinder
Capacity 2294cc
Bore/Stroke 101.6 x 94.3mm
Compression Ratio 8.7:1
Fuel System Multipoint sequential electronic fuel injection
Ignition Digital - inductive type - via electronic engine management system
Transmission Primary Drive Gear
Final Drive Shaft
Clutch Wet, multi-plate
Gearbox 5-speed
Cycle Parts Frame Tubular steel, twin spine
Swingarm Twin-sided, steel
Front Wheel Alloy 5-spoke, 17 x 3.5in
Rear Wheel Alloy 5-spoke, 16 x 7.5in
Front Tyre 150/80 R 17
Rear Tyre 240/50 R 16
Front Suspension 43mm upside down forks
Rear Suspension Chromed spring twin shocks with adjustable preload
Front Brakes Twin 320mm floating discs, 4 piston calipers
Rear Brakes Single 316mm disc, 2 piston caliper
Dimensions Length 2500mm (98.4in)
Width (Handlebars) 970mm (38.2in)
Height 1165mm (45.9in)
Seat Height 740mm (29.1in)
Wheelbase 1695mm (66.7in)
Rake/Trail 32 degree/152mm
Weight (Dry) 704lbs
Fuel Tank Capacity 6.3 gal
Performance (Measured at crankshaft to DIN 70020) Maximum Power 142PS (140bhp) at 6,000 rpm
Maximum Torque 200Nm (147ft.lbf) at 2,500 rpm
Colours
Mulberry Red, Phantom Black
Capacity 2294cc
Final Drive Shaft
Gearbox 5-speed
Front Tyre Front 150/80 R 17
Rake/Trail 32°/152mm
Weight (Dry) 704lbs
Colours
Phantom Black/Sunset Red, Pacific Blue/New England White, Phantom Black/Tornado Red
Capacity 2294cc
Final Drive Shaft
Gearbox 5-speed
Weight (Dry) 320kg (704lbs)
Fuel Tank Capacity 24 litres (6.3 gal US)
Colours
Phantom Black/Cardinal Red, Eclipse Blue/Graphite, Jet Black/New England White
é pouca coisa mais potente que a nossa mirage250 hehehehhehehehehehe :lol: :lol: :lol:
luisasilveira
Registrado em: 22 Jun 2007, 15:12
a 1ª é linda!!
Vi uma dessas no sábado na Av. Santo Amaro(São Paulo), como é linda... 8)
joviman escreveu:Vi uma dessas no sábado na Av. Santo Amaro(São Paulo), como é linda... 8)
aqui na minha cidade só vejo titan, ybr e biz hehehehehheeheeh :lol: :lol: :lol:
DADOS TÉCNICOS:
Motor: Líquido de refrigeração, DOHC, in-line 3- cilindro.
Cilindrada 2294cc
Diâmetro x Curso 101.6 x 94.3mm
Taxa de compressão 8.7:1
Sistema de Combustível Injeção eletrônica seqüencial multipoint do combustível.
Ignição Digital - tipo indutivo - através do sistema de gerência eletrônico do motor.
Transmissão
Transmissão primária Engrenagens
Transmissão secundária Eixo
Embreagem 5-speed
Chassi
Quadro Berço em aço tubular.
Balança Gêmeo-tom o partido, aço.
Suspensões
Dianteira 43mm forquilhas de cabeça para baixo.
Traseira Os choques cromados do gêmeo da mola com preload ajustável.
Freios
Dianteiro Twin discos flutuando de 320mm, 4 compassos de calibre do pistão.
Traseiro Escolha o disco de 316mm, compasso de calibre de 2 pistões.
Pneus e Rodas
Roda dianteira Liga leve, aro 17 x 3 polegadas
Pneu dianteiro 150/80 R 17
Roda traseira Liga leve, aro 16 x 7 polegadas.
Pneu traseiro 240/50 R 16
Dimensões e Pesos
Comprimento 2.500 mm
Largura 970 mm
Altura 1.165 mm
Distância entre eixos 1.695 mm
Altura do assento 740 mm
Tanque de combustível 24 litros
Peso a seco 320 kg
luisasilveira
lembra a v-max!
Postagem do Rafa:
DADOS TÉCNICOS:
Cilindrada 2294cc
Transmissão
Embreagem 5-speed
Chassi
Suspensões
Freios
Pneus e Rodas
Dimensões e Pesos
Largura 970 mm
Altura 1.165 mm
Peso a seco 320 kg
