BHC-3 ZZ4 - Especificações
Motos: Daelim, Kymco, Miza, Shineray, etc.
Boss Hoss BHC-3 ZZ4
Engine
Type
Liquid Cooled V-8
Horsepower
355 @ 5250 rpm
Torque
405 Ft.Lbs @ 3500 rpm
Block
Cast Iron - 4 bolt main
Cylinders
Aluminum (58cc)
Valvetrain
1.94"Int / 1.5"Exh.
Size
350 c.i. (5700cc)
Compression
10:1
Carburetor
Holley 750 cfm
Exhaust
2.0" with dual mufflers
Transmission
2-speed semi-auto w/rev.
Final Drive
Belt, Gates- Polychain
Dimensions
Overall Length
106"
Wheel Base
80.0"
Seat Height
28.0"
Rake
33.0 degrees
Grd. Dlearance
4.5"
Frame Width
28.0"
GVWR
1675 lbs.
Dry Weight
1100 lbs.
Tires/Wheels
Front
130/90-16, 3.50"x16.0"
Rear
230/60, 7.0"x15.0"
Suspension (Adj. Preload)
Front
63mm inverted forks, 3.5" travel
Rear
Dual 13.0" coilover shocks
Brakes
Front
Dual four-piston calipers, 12.6" floating disc
Rear
Single four-piston caliper, 12.6" floating disk
Fuel
Tank
8.5 gal.
Reserve
n/a
High/Low MPG
25/20
http://www.bosshoss.net
heheeee
deve ser bem "leve" hehehe esse motor v8 deve ser mais leve que as nossas mirage hehehehhehehh
gostei da potencia 355cv hehehe
AugustoAmaral
Registrado em: 27 Set 2008, 15:49
essa nave faz qnts KM/L, ou seria qnts L/KM?
hhehehehee
Orgulho de ser Nordestino
Os Inocentes Moto Grupo
coyotebeatts
Registrado em: 16 Abr 2009, 20:55
...loucura, loucura, loucura:
http://www.bosshoss.com
...depois digam o que acharam!!!
Paul0 Pint0 - Guaratinguetá/SP.
- aguardando a Horizon, com um olho na GR250T3!!!
Antonio
Registrado em: 09 Mai 2009, 18:20
Linda, e sendo v8 fica perfeita.
Quanto sera que custa uma dessa?
