Boss Hoss BHC-3 ZZ4
Engine
Type
Liquid Cooled V-8
Horsepower
355 @ 5250 rpm
Torque
405 Ft.Lbs @ 3500 rpm
Block
Cast Iron - 4 bolt main
Cylinders
Aluminum (58cc)
Valvetrain
1.94"Int / 1.5"Exh.
Size
350 c.i. (5700cc)
Compression
10:1
Carburetor
Holley 750 cfm
Exhaust
2.0" with dual mufflers
Transmission
2-speed semi-auto w/rev.
Final Drive
Belt, Gates- Polychain
Dimensions
Overall Length
106"
Wheel Base
80.0"
Seat Height
28.0"
Rake
33.0 degrees
Grd. Dlearance
4.5"
Frame Width
28.0"
GVWR
1675 lbs.
Dry Weight
1100 lbs.
Tires/Wheels
Front
130/90-16, 3.50"x16.0"
Rear
230/60, 7.0"x15.0"
Suspension (Adj. Preload)
Front
63mm inverted forks, 3.5" travel
Rear
Dual 13.0" coilover shocks
Brakes
Front
Dual four-piston calipers, 12.6" floating disc
Rear
Single four-piston caliper, 12.6" floating disk
Fuel
Tank
8.5 gal.
Reserve
n/a
High/Low MPG
25/20
http://www.bosshoss.net
