Model: Yamaha XVS 400 DragStar 2001
Category: Cruiser
Specifications
Engine and transmission
Displacement: 400.00 ccm (24.41 cubic inches)
Engine type: V2
Stroke: 4
Power: 32.18 HP (23.5 kW)) @ 7500 RPM
Torque: 32.00 Nm (3.3 kgf-m or 23.6 ft.lbs) @ 6000 RPM
Compression: 9.7:1
Bore x stroke: 68.0 x 55.0 mm (2.7 x 2.2 inches)
Fuel system: Carburettor. BDS28×2
Fuel control: SOHC
Ignition: T.C.I. Formula
Cooling system: Air
Speed and acceleration
Power/weight ratio: 0.1430 HP/kg
Dimensions
Dry weight: 225.0 kg (496.0 pounds)
Seat height: 660 mm (26.0 inches) If adjustable, lowest setting.
Overall height: 1,095 mm (43.1 inches)
Overall length: 2,340 mm (92.1 inches)
Overall width: 895 mm (35.2 inches)
Ground clearance: 145 mm (5.7 inches)
Wheelbase: 1,610 mm (63.4 inches)
Chassis
Frame type: Double cradle
Front suspension: Telescopic forks
Front suspension travel: 140 mm (5.5 inches)
Rear suspension: Swingarm Monocross
Rear suspension travel: 113 mm (4.4 inches)
Tires
Front tyre dimensions: 110/90-18
Rear tyre dimensions: 170/80-15
Brakes
Front brakes: Double disc
Front brakes diameter: 298 mm (11.7 inches)
Rear brakes: Single disc
Rear brakes diameter: 282 mm (11.1 inches)
Capacity
Fuel capacity: 15.00 litres (3.96 gallons)
Country of origin
Japan
